starter
355SS
13
i tried to install a caprice lt1 starter in my monte carlo last night. the block is from a 1980 the starter is too far away from flywheel. all the research i did it said it would work any ideas
thanks
HP JUNKEY
1,093
Buffalo.NY
Sounds like you have a 153 tooth flywheel, and the starter is for the 168 tooth flywheel,,,,,,,,,,,,
355SS
13
its for a 153 tooth flywheel those cars had that and its a straight accross bolt pattern on starter
HP JUNKEY
1,093
Buffalo.NY
:-k :-k got me there,,,,,,so the starter does not engage the flywheel at all?
355SS
13
it does but it grinds bad and i can pull the bendix drive out and its too far away
HP JUNKEY
1,093
Buffalo.NY
I know some/most of the aftermarket mini gear reduction starters require shimming,,,by adding a shim or 2 to the mounting surface at the block and adding the shims between the starter block and the starter body. The Bendix gear on the starter should mesh with the flywheel and have 1/8th" clearance between them, I have used a paper clip to check it. The Bendix gear should only contacts the flywheel teeth 1/2 to 2/3rds the thickness of the flywheel teeth. I'm pretty sure the clearances are the same with the aftermarket starter and the "factory" style you have. sounds like you may have to shim it if it is grinding.....maybe search you-tube or the inter-web for a video??
355SS
13
if i shim it it gets worse i need to move it closer to flywheel
HP JUNKEY
1,093
Buffalo.NY
HMMMMMMM,,,,I am at a loss then, maybe someone else will chime in.............
WhiteTrash79MC
942
Reading, PA
Do have a "Ford" style solenoid feediing the starter? I put a LT1 starter on my car and it was grinding bad. No amount of shimming would fix it even tried half shims...found out that those starters need constant power or the bendix doesn't retract all the way and causes grinding. I ditched the "Ford" solenoid and problem solved.
