so while I was installing the T-56 in the Malibu I decided I was tired of the exhaust leaks, road clearance issues with the Hooker 2241's on my BBC. I bought a set of 2455's for the older BBC A-Bodys and made them fit. its a very straight forward deal. Besides a few hammer dimples you only need to move one tube, so I bought a 2" U bend from Speedway and went to town (thinking back if you had a way to cut an identical pie cut into the primary tubes where they come off the flange and bend down so you could tuck the header tighter to the block you wouldn't even need to move the one tube)
but anyway heres a small description and a few pics to answer some questions I've been asked
in this pic i had started cutting but the tube wasn't in pieces yet (forgot to snap the pic first...got excited lol) the upper cut wasn't all the way through, I just pie cut it and bent it pretty much 90° to the collector then welded it up
and this one is after I test fitted them, tacked em up and welded them...I left the piece that I replaced there as a reference...you'll have to ding up a couple tubes just a little and trim the lower control arm mounts back but they are alot cheaper than the super comps...I've got about $375 in mine after having them coated
and finally the finished product (crappy cel phone pic)
all in all I probably spent 3-4 hours from start to finish
