Here's the old crossmember. It's a
hacked-up job I done to fit the TH400 into the Malibu. It worked well for the few
years I had it in the Malibu. Notice the dual exhaust modification and the
transmission mounting pad I fabricated out of flat steel. It had to be moved to the
rear side of the crossmember to mount the TH400. |
Here's what you get with the TH400 installation
into a pre-84 G-body. It comes with the crossmember, frame extension, fasteners,
template and instructions. |
The pre-84 (and in some cases '85) G-bodies have
a shorter frame extension for crossmember mounting. The later models were available
with the 2004R transmission, so they had longer frame mounts for the crossmember.
Here is a shot of the frame section that needs to be extended in order to install
the G-Force crossmember. |
The frame extension is a really slick way to
cure the pre-84 mounting problem. It simply slides into the frame rail, and has bolt
holes to bolt it into place in the existing factory holes. Later, you drill two
small 1/2" holes in the framerail near the rear of the extension to securely mount it
to the frame. Note: you may have to move or slightly relocate (bend) the fuel
vapor return line. No biggie for me since I had already removed mine. Very nice. |
Next, you slide the crossmember into place.
Goes in pretty easy, and fits great. Everything lined up without much trouble
at all. |
Here's where the frame extension on the driver's
side comes into play. As you can see here, it is a nice fit. All bolts are put
into place and finger tightened to make sure everything lines up properly before final
tightening. |
 Here's the transmission mount. It fits
perfectly and looks great. You have a large hole in the bottom to install the nut
with a socket. |
 OK, everything is lined up and tightened down.
I removed the floor jack, and the transmission is resting on the crossmember. |
 Here's the rear view of the crossmember after it
has been bolted into place. Note that my shifter cable is hanging down. I had
to re-route it to where it rests on top of the crossmember on each side of the
transmission mount area. |
 Next step is to re-install the driveshaft. Note that it is a 3.5"
diameter shaft and it is TIGHT around the driveshaft safety loop. |
 Close-up of the driveshaft, safety loop, and crossmember. |
 Here is where I used the supplied template to drill
the two holes into the frame to securely mount the rear part of the extension. This
was the hardest part, but drilling two holes isn't too difficult! |
 Since the framerail has a slight drop on the
inside, you have to use some shims that come with the kit between the extension and
framerail where the bolts pass through. |
 Here's the passenger side exhaust pipe. It is a 3" pipe, and has
PLENTY of room! |
 Same for the driver's side. There's plenty of
room for a bigger pipe. |
