12 Bolt Axles
Jayz81ss
115
Ontario, Canada
Racing season here has ended so it's time to rip the motor down and inspect it along with the rest of the car.
My question is when should I replace the stock axles in my 12 bolt rear?
I am already running a spool and c-clip eliminators.
The car weighs 3600 lbs with driver
I launch at 3600 on the t-brake and 1.53 60 foot times
Thanks
Jay
Goob
3,641
Indianapolis
When they twist more than 1 or 2 splines, if you want to wait.
Keep in mind that aftermarket axles are required at 10.99 or quicker.
http://www.tomsdifferentials.com
Jayz81ss
115
Ontario, Canada
Thanks Goob
Yeah I know I need axles after 10.99.
If the budget is ok after checking over the motor I was planning on upgrading them.
I was just curious if I was putting them to thier limit or not.
Goob
3,641
Indianapolis
As long as you are footbraking, they'll probably last a while.
You just don't want one breaking outboard of the bearing, and factory axles are weak out there.
