12 bolt in a g body looking for suggestions
64chevelle
61
wichita ks
Ok guys think its time to do some upgrades to rear suspension...Im looking to better 60ft basically rear is not going away so if you have some ideas please help.
I currently have iceman upper arm adj swap control arm and soild lower bars.
also have umi relocated brackets welded in to have the option of moving them.
all points have been drilled and installed 1/2" hardware.
also have a weld in iceman ARB
I am looking into installing trz upper bushing in the rear as I currently have poly in there
or looking in to baseline suspension upper control arm trick piece??
I talked with TRZ the other day and basically said I need to lower the car 2-3" to get the upper arms where I need them? Here are a few measurements I took today
rear upper control arm bolt height 18.25"
front upper control arm bolt height 18.75"
rear lower bolt height 9.25"
front lower bolt height 10"
front weight of car is 1678..... rear weight is 1542 camshaft height is 21"
car has been 9.50s @ 146 with a 1.40 60ft on drag radials
I have strange single adj shocks out back and comp eng 3 ways up front
gman415
883
Chattanooga
Using 19.5 for the lower length, and 11.25 for the upper, I'm comming up with your IC 1500' BEHIND the axle CL.
I'm doing this on autocad, but may be doing it wrong (maybe someone could check)
64chevelle
61
wichita ks
man all these bench racers and not one suggestion??? here is a video of car down the track..
http://www.youtube.com/watch?v=021MZewFNp8
footbrake 1.44 60ft
Mike Allred
219
Fayetteville, NC
I have the Iceman upper & lower 12 bolt swap control arms and the IC never happens with the extended control arm intersect point diverging. No hop bars or the "trick" Baseline suspensions uca piece would improve geometry to at least bring the IC together. My car hooks ok but does squat on launch with the current diverging IC. The tires will plant a lot better by raising the uca rear mount point (at rear housing) 3 1/2 inches or so.
-- Get the baseline suspensions kit!
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
i'll give you a suggestion based on your video that should impove your 60'. Get a convertor with a 1000 rpm more stall. You suspension looks to be working good.
brian
78boo0
416
HAZEL PARK, mi
www.niacandles.com
i have the baseline set-up
an over the winter i have rear coil-over going on the front have singal adjustable i have TRZ arb
Supe
15,116
Charlotte, NC
brian
Ding ding. You're not getting much body separation and you don't appear to be spinning. You can change all the rear suspension parts in the world right now and get the same 60 foots. You can hear the motor labor off the line. Needs more converter, IMO.
1QuickGM
386
Niles, Michigan
I would have to agree with the others, bigger converter or put a 100 shot on it with that converter! LOL
Looks like it is making good power laying down that time with a 1.4 60'.
64chevelle
61
wichita ks
guys in that video the progressive was stretched out a lot. Also I have a transmission brake but could never get it to hook on drag radial off the brake. Car stalls to 4200 on the brake.
