Yes it should bolt in just like the chevy 12 bolt, the mounting points should be the same, but be forewarned, the pontiac(B.O.P.) 12 bolt rear is not internally the same or as strong as a chevy 12 bolt. Do a little research on that rear end before you spend a lot of $$$ on it. A pontiac 12 bolt rear will have a 12 bolt cover, but has a 10 bolt ring gear that is IIRC a 8.2" or something close. Also has a small diameter pinion gear shaft. Chevy 12 bolt is 8.75" ring gear with 12 bolts attaching the ring gear and also 12 bolts attaching the rear cover. Like I said, just do some checking on it.
