1le swap... m/c question
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
so i did the 1le swap on my wagon, and all is good... but it feels as though i could have better brakes. is there a different m/c, booster that i can use without changing much else? i have stock rears as well.
thanks!
MISFITmalibu63
7,163
anyone??
355_79bu
1,240
Cotter, AR
When You say you feel you could have "better brakes" what are you feeling?
Hard or soft pedal? Too much pedal travel? Something else?
388bu
3,228
Huntley, il
www.shiftn6.com
You want a b-body m/c and id go with a g-body dual diaphragm booster if you have a single currently. Although, some duals wont work with the b-body m/c and I cant tell you how to know which will/wont work.
gparts.freeyellow.com will list the p/n for the m/c you need I believe.
MISFITmalibu63
7,163
feels like theres too much pedal and its still a little soft.
4,654
31
That is why you need the larger bore B body master cylinder.
Have a look at what Bob Morris did with his MCSS brakes. He installed a dual diaphragm B body booster and a B body master cylinder.
http://garage-scene.com/manual-trans-monte/1986_mcss_bob_morris.htm
I need to update his proflie, he now has a 427 SBC.
MISFITmalibu63
7,163
thanks!
im gonna pick up a b-body diaphragm and m/c and get to work!
