Yes, the TH350 will bolt right up to the 229. It was a common swap when people couldn't get the 200 to work properly.
I'm not sure the usage of the TH250, but it was another light duty trans. Maybe not as light as the 200, but not as good as the 350.
Edit: I found some info on the trans applications. The TH250 was used on some of the 4.4 and 5.0 V8s, it shared the same gear ratios as the TH350.
The 200c was used on the 229 as well as some 305s. Of course it's a light duty, but also has lower 1st, 2nd, and reverse gears @ 2.74, 1.57, and 2.07. Verses the other THMs with 2.52, 1.52, and 1.93.
