Here is my problem I am putting a 3.73 Posi in my stock housing of my 80 Bu. When I tighten the pinion nut I can still move the shaft about a 1/16 up and down and front and back. With it out of the car I made sure the nut would bottom out and the yoke. I told NAPA to take the shim from the old pinion shaft and put it on the new one. All the bearings are new. I think there is a shim under the new bearing but I cannot be 100% sure. Assuming it is could I just need a thicker shim ? Where can you buy the shims I did not see them listed with any of the local places ?
