For you guys that's using a 700r4 behind your ls motor what kind of tv cable bracket are you using? also I read that if you have the constent pressure valvebody(which keeps the pressure @ the same psi) in the 700r4 then the bracket would not have to use a tv bracket? I'm not sure how true this is.
