81 EL CAMINO LS1
81elcamaro
30
progress..... ......cleaned,sanded and painted......
81elcamaro
30
1 inch set back plates, stock 350 mounts, stock clam shells.. ice man crossmember ...ls1 camaro pacesetter headers.....
81elcamaro
30
drivers header almost fit but i had to bend the firewall seam just a lil to get the header in,passenger header hit the frame so i had the primary cut and moved in a lil to get it by the frame
81elcamaro
30
the oil dip stick tube screw didnt want to clear the header lip so it had to be ground down a lil....02 sensor extensions new hydraulic clutch set up
81elcamaro
30
the old straps cleaned up well?left side rubberized right side rubberized and painted4.3 sending unit and tank
81elcamaro
30
corvette fuel filter and regulator with an6 fittings
81elcamaro
30
the clutch cylinder is in i used the old brake pedal for a clutch extension lol.
81elcamaro
30
the dreaded ac box :shock: !!! the back coil pack was digging into the ac box i trimmed down the coil pack bracket as much as i could then i decided to try my hand at fiberglassin, i mean how hard could it be right??? :roll: so i placed a plastic bag around the old heater core put in where it belonged then shaped the fiberglass matt to the desired shape
81elcamaro
30
removed the heater core and test fit the box , :?: it was perfect dancin_banana.gif ,time to learn how to bondo! after ALOT of repeated bondo and sanding i shot on a lil high temp paint
81elcamaro
30
plenty of room i took apart the entire ac box inside the cabin and cleaned it with bleach and soap before painting and placing it back in
