9" ford guys ???
jaywill
642
REIDSVILLE,NC
What size rim & backspacing u r running on your cars ???
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
No 9" can just be bolted in without narrowing. So once its built to fit a G-body I run a 15x8 wheel with 4" backspace. A 3.5" backspace will work better if you are running a tire with lots of sidewall bulge. Another option is a a 15x10 wheel with 4" backspace if you run a 26" tall tire and the back of the car is stock height. I have this setup on a 78 Lemans and it looks kinda "Ghetto" but don't put anyone in the back seat or the tires will rub.
Brian
jaywill
642
REIDSVILLE,NC
Brian
I have A g- body 9 inch I am installing now..thanks
prairiehotrodder
1,576
4
you want 5x4.75 to match the front of the car. 5x4.5 is ford bolt pattern. Some wheels have both so that could work for you.
jaywill
642
REIDSVILLE,NC
it has 4.5...the guy i got it from said he had a 15x10 on the rear..
