Adjusting front drag shock Question
attngtr
364
Eastern Iowa
I purchased a set of front drag shocks and the directions are pretty vague. It has settings for R(regular), F(firm) and XF(extra firm). My question is which one is 90/10, 80/20 and 60/40. What is used most for drag racing 90/10? If so what is 90 (slower rise?) and what is 10 (faster fall?)?
Supe
15,116
Charlotte, NC
It depends on the brand. Comp and Summit were backwards, I believe the Summit had 90/10 as being extra firm. The 90/10 will have loose extension, stiff compression.
attngtr
364
Eastern Iowa
Yeah they are summit brand which I believe are comp eng. So 90 is faster rise and 10 is for compression?
GreenDragginBu
6,293
N.E. Ohio
Yes My Comps were backward as supe mentioned.
rock
2,475
Chicagoland area
hope this helps
http://rds.yahoo.com/_ylt=A0geu9wIcl9JyXMAsvxXNyoA;_ylu=X3oDMTEyOTh2M2ZsBHNlYwNzcgRwb3MDMQRjb2xvA2FjMgR2dGlkA0Y2NTRfNzM-/SIG=12nrg7u6v/EXP=1231078280/**http%3a//www.competitionengineering.com/catalog/images/c2600_inst.pdf
dasbrdr
411
Seattle, Wa
Based on my experience, the summit shocks are not comps. The comps were a far better shock (i've had both). That being said, the comps are not a very good shock either. There are tons of better shocks out there. And yes they both adjust as stated above.
MalibuMan1979
506
flint, (lapeer), michigan
check out baseline suspensions, (sponsor link), at the top. great chassis info and they explain shock proportions for drag racing. all explanations are done in english, (for people like me who can't understand techno stuff). great site.
