air bag install finished with pics added thanks guys
purple barney
576
Raleigh NC
which way do you guys that are running air bags put them in. the instruction say the nipple should be point down toward the rear end. theres no hole in the lower spring pearch to run the air line through. it seems the nipple should be pointing up towards the trunk of the car?????? please help
Sikmalibu
744
Central NJ
Re: air bag install
When I had mine in there was a hole in the spring perch up top, and all I did was I put the nipple through there and ran the line to it. Very simple.
Malibuwagon80
1,255
Re: air bag install
I got the quick performance rear also, I drilled a hole in the perch and ran the line through there. Wagondude
purple barney
576
Raleigh NC
Re: air bag install
thanks wagondude thats what i figured after the first response i just finished it looks good 8)
