I know this is an old thread however, hope I can help you out a bit....
We used to wrap these bads with duct tape not tightly reinsert them into the coil springs and generally air them up to 25 psi on the drivers side and 30 psi on the pass side this paticular GN would 60' in the low-mid 1.4 range.. if your your car does not hit the tires as hard you can get away with 15 drivers and 20 pass side... also while you are under the car check your pinion snubber mounted above the pinion if it is not clean it is not making contact so make a spacer from 1x1 steel stock about 3.5" long
