all spare parts combo
Twister79
163
Orangeburg, SC
i have an 355ci sbc motor with forged inverted dome pistons
motor has head studs and main studs, o-rings and the block has been deck
it has holley system max heads with 1.5 roller rockers ,heads are 190 runners 2.02 1.60 valves 67cc
victor jr intake with an 750 holley hp
an lunati drag solid roller 4500-8500 rpm .656int/.668exh lift ,316int/330exh adv dur
gear drive timeing ,scat steel crank ,all these parts are spare parts i used to build this motor i wanted to get you guys opinion on you think its going to run its going in a 79 camaro with a th350 3000-3500 stall and 4.56 gears with mt 28 x 10.5 tires car has lexan windows, guted doors ,feul cell ,fiberglass hood and trunk, one jegs raceing seat (give me some 8th mile times on motor and with an 250 nitrous plate system)
sbmalibu
623
north judson indiana
Its not gonna have much compression but with a little looser converter or a 250 shot should run real good.
Twister79
163
Orangeburg, SC
anyone else have any guess
Twister79
163
Orangeburg, SC
spare parts combo almost complete
Night Stalker
1,125
Genoa,Oh
with what you have there be happy if it's 9.1 compression....which in any case find a 6500 converter and 4.88 gears,, it should move then.. :mrgreen:
sbmalibu
623
Would be a awesome blower or turbo motor with a little different cam. 8)
Twister79
163
Orangeburg, SC
hey guys on this same combo i listed iam going to put this setup in an 84 cuttlas ,4.10 gears ,th 350 trans, 27x10.5 et drag tires can u guys give me some 8th mile times but iam going to use a 3500-3800 stall
Night Stalker
1,125
Genoa,Oh
It's hard to say,,but i'm sure the track will pull out the "sun-dial" to clock you going down the track... :mrgreen: :mrgreen:
In all seriousness,, install an alcohol carb on top that combo as the low compression and alky will wake that motor up BIGTIME!! ;) ;) the alky will help raise the static compression in the motor and build alot of torque.. \:D/
