what is 10 lbs residual valve? I see alot of talk on here about it
also are you guy calling the porpotioning valvle the combination valve?
I have just put a New Stock Manual Master cyl. on my car, (figured out my brake pedal problem). I have new calipers, and the wheel cyl on the rear are not leaking, but I noticed that when I am pumping up the brakes and hold it. The pedal slowly bleeds down. I see no fluid leaking so WHY is the brake pedal slowly going to the floor? The Master Cyl. I bought from O'reillys is suppose to be for a manual brake 79 malibu.
your thoughts are greatly apprecatied.
