Orange...I did pay attention... He asked how strange kept the oil from leaking out of the housing...Please reread what you quoted.. Thanks.
I only stated that YOU (everyone) should not weld to any aftermarket axles as it voids the warranty... (maybe other people did not know this info and I thought it was GOOD to know. Please read the info thoroughly before chopping people up...You asked for info I gave you what you wanted ... and then some extra and I get all chopped up...Geez. =D>
As far as your friends strange c-clip elim kit leaking by professional install ??? I do not know if they are stock axles or aftermarket axles. I also do not know if they cut the end of the tube to the proper distance as stated in the directions...Lastly I do not know who these 'Professionals are?? ' I LOVE that term by the way PROFESSIONAL- this must be above all us standard HUMANS...LOL \
/ So I can speak for them and to how good they are at their profession. Is that all they do? rear differential or are they GENERAL Professional mechanics....????
I am NOT perfect by any means.(1st to admit that) If they keep trying to stop the leak and nothing is successful I would say we have some defective parts or as stated earlier backing plates are not true 'O' ring is shot...You will NOT be able to see that. Best way to try to help to figure out where the problem lies clean as well as possible and try to pin point the leak area. AND this is the exact reason we do not use the strange elim kit...Moser elim kit only ONE place to leak from the backing plate to the elim block.
The steel clip in the block... Some use a snap ring to hold the bearing into the alum block housing...BUT tack welding AGAIN??? GEEZ someone should take the welder from who ever you got this stuff from...lol.
I would say you are destine for a long life of headaches from the sounds of what was done to all the parts.
I guess all you can do is gum up the works the best you can and cross them fingers. I do wish you the best on the leak problem.
One more question...Is this elim kit on a G-body rear that had to be drilled to fit or are they on a standard 4 bolt hole backing plate system like the old chevelle muscle car era?
Axle studs are a press fit they have knurls that smash and cut into the drilled hole. so the hole will be .472 and the press in stud will have a .480 knurl over sized so it will cut into the hole...too many in and outs and the hole will be used up and loose...Which brings us to a whole other problem ...but that is personal.
curse_sign.gif dancin_banana.gif lame_sign.gif [-X
Hope the info HELPS and I am not here to cut anyone down or make them look bad or dumb. Just giving free info. Take care. Jim
