11 inch wheel with 6.5 bs with 28x11.50 tire without cutting the frame
Could it be done by cutting the fender lip all the way to the fender?
MalibuJack said:I don't think you'd pull it off with 6.5" BS.. I have tried 15x10 with 5.5" BS before the frame notch, the tire size itself might fit if you can get the backspace right. I think you might be pushing it though unless the car is drag only.
You should go to a high-end wheel distributor and rent a wheel fitment jig to find the exact backspace and where your setup needs tweaking (fender lips, frame rails, wheel tubs)
