Howdy folks,
I have been fighting with a vibration problem in my 86 regal for some time after a t56 swap(low pitch vibe in 5th and 6th at around 73 and up). part of the problem is the fact that i was working on my back and, like a jackass, was rushing and didn't plan ahead enough to take better measurements when i pulled the 4l60e to swap in the t56. I welded a new perch to a 200r4 crossmember for the rear mount after getting the trans and rear at the same angle, but i have pretty much ruled out everything else and want to try to get the back of the trans as close to the stock regal angle as possible. can anyone with a stock suspension g-body and a t56 with no driveline problems give me a quick angle measurement at the tailshaft when the car is either sitting on the wheels or with the frame level on a lift? if not, does anyone have a t56 crossmember sitting around and can give me a quick measurement of the relationship between the frame mount surface(the surface that actually contacts the frame when mounted) and the top of the trans perch?
Thanks
By the way, i already had a new 3.5 inch aluminum driveshaft made to replace the stock one, replaced the drums with new ones, and looked for exhaust hitting the frame, etc. I have also been told that a possible reason this happens is because when my trans went back together the 5/6 gear just slipped into place but it is supposed to be a press fit, so the 5/6 gear may be causing a vibe due to the gear not being as tight on the shaft as it is supposed to be. I am pretty sure i swapped my wheels around also, but i will give that another try just for the hell of it too in case i didn't.
Thanks
