Anyone running 20X10's without modifying the factory tubs?
79buproject
Northern Kentucky
Anyone running 20X10's without having to cut/modify the factory wheel tubs? I have a Chris Alston Fab9 housing that I purchased brand new. When I bought it, I had it narrowed 1" on both ends. I've also purchased a set of 20X10 rear wheels with a 5.25" backspace (I think?). Anyone know if I'm going to run into problems with this? Am I going to have to widin the factory tubs? Thanks in advance for the help?
StreetBu
4,158
3
Upstate NY
Re: Anyone running 20X10's without modifying the factory tub
I'm fairly sure you will have to cut the rear tubs out and move them in to fit a 10" wheel back there. Some guys can do it but they arent lowered, mainly drag guys running a 28 or 30" tall tire.
grizwald
3,300
Ontario, Canada
if you have a rearend that is 1" narrower per side, and rims with 5.25" of backspacing, I'm thinking the frame will stop you from even bolting the rear wheels on.
79buproject
Northern Kentucky
I have already notched the framerails with that in mind. I'm fairly confident that the wheels with fit on the rearend withouth clearance issues. My only concern are the wheel tubs....
