Anyone using stock colum shifter w/4l60e?
TurboBu
32
Sw Missouri
I've got a 78 bu 5.3 4l60e swap car with a bench seat. Wanting to keep the floor clear for my honey's legs. So I want to keep the stock shifter. have looked at Lokar cable linkage but it doesn't look like it will work.
DOUG213XRJ
4,671
West, MI
I think theres room in the stock shifting linkage to get all the gears when shifting manual . Doug
Deuce4935
341
Chicago, Il
kugel components shifter linkage is another option,
Stangboy
833
Ky
Im wanting to column shift my 4l80e, but its a ways off... years at the current pace im on...
Keystone Mark
The stock column shifter will work. I have an 80 Bu with a 5.3/4L60E. The engine is mounted with the Transdapt 1" setback adapters and the stock clamshells and frame pads. I had to trim the back coil stand off of the pass side valve cover and trim the coil bracket to clear the AC box. It is tight to the firewall but clears. The truck PS pulley clears the PS steering box. The shifter linkage from the TH350 bolted to the 4L60E and only needed a small adjustment. I am using an Ididit PRNDL on the column for gear indicator. It needs a little shimming to fit but works nicely.
2aspire
New Member
Oct 26, 2010
3
I have an 86 monte SS (LS2 4L65E) and used John Bzdels custom mounts wich place the motor in essence about the same as the trans dapt 1" offset mounts..
I was able to hook up the column shift but the hassle is the header clearance.. Had to go custom as I couldnt get a set that would clear the shift linkage in addition to other areas that would require a BFH to "massage: as others have called it, to get a set to fit..
Keystone Mark
I used f-body exhaust manifolds and the linkage fit without a problem. My exhaust guy mounted the cats behind the crossmember to give extra clearance for the pipes and keep heat away from the trans.
79loserbluebu
302
Illinois-60491
Cats? Are you in California?
Keystone Mark
We all have to breathe the air. I am in PA and had the car registered as an antique so I don't even have to worry about inspection. I am not running rear O2 sensors so it wasn't about OBD2. It was the right thing to do
