Installed my oil pump stud the other day and i tightened it into the main cap as far as it would go. This was before I found thar u were only supposed to have the stud hand tight. I plan to fix the problem this weekend but I'm worried if i might have bottomed it out against the bearing. Is that even possible or am I just worrying too much? I have only turned the motor over once since I installed it. If it has bottemed out is it possible that I have damaged the bearing?
