Anyone ever had any issues with this gauge? I'm not sure if I have an electrical issue or a Trans issue? I'm hoping to god its electrical. The sending unit for this gauge is in the trans temp cooler line going into the cooler and it works great for the first bit. I'm able to drive and get the trans temp up to about 150-165 degrees or so, and without warning the reading on the gauge will suddenly spike to its max reading. I figured maybe an air bubble or the trans was running low on fluid and wasn't pumping anything to the cooler.? so i checked fluid level and it was low.... I have been adding fluid 1/2 quart at a time and checking. Its up to a good level now and it still does it? Anyone ever had this problem? I'm thinking that I'm gonna drop the pan and add a bung so i can put the temp sensor right in the pan.
The fluid smells sweet and using a thermo temp heat gun the pan temp only reads 160 degrees when the gauge is reading 250+
Any ideas or experience with this would be appreciated.
Thanks,
Jim
Thanks,
Jim
