B & M pro ratchet shifter
79izfine
2,199
massachusetts
what i would like to know is the shifter was for a reverse pattern valve body my trans has a foreward shift valve body is there a difference when i look up application it lists make model etc in foreward and reverse are the shifters the same or 2 different shifter with same part ## thanks
Al
2,018
Harker Heights, TX
I've never used this particular shifter, but the Quicksilver I used to have didn't make a difference if it was forward or reverse pattern. Since the Proratchet appears to be based on the Quicksilver design I would think it would be the same.
mreese
171
KILGORE TX
it is for forward or reverse pattern valvebody i have used mine for both
79izfine
2,199
massachusetts
i had a feelin it was for both seeing summit listed one part # just wanted to confirm .. now i just have to get used to pushing the lever to ratchet into park think its gonna be a pita thanks for both your info
