Went to bleed the brakes on the monte the other day and had a problem. Bleed the rear passenger brake fine and went to the rear drivers side. I cracked the bleeder screw open and no fluid comes out even after 10+ pumps of the pedal. So i disconnected the brake line running from the drum that goes to the lil distributino block on the rear end and fluid was coming out. Could the wheel cylinder be bad? I already checked the bleeder screw and it's not clogged...
