X2 on the timing. My 350 likes ALOT of timing, but I found out the first time i went to restart it that I had to back it down a degree or 6
I forgot to mention the star washers as well, they help "bite" into the metal and make better ground.
Also how is your starter to block ground situation. When I painted my engine, I forgot to mask off the starter area. Needless to say that was
situation.
I've gotten by with a cheap (WalMart) 550 CCA battery before, but I gotta say my 720 CCA Red Top sure performs a lot better, and allows me to really crank up the timing advance.
And last of all what condition are your pos/neg cables in? If they're original I'd replace them or at least check them thoroughly. My friend had trouble with this nova he got, long story short he noticed a small nick in the ground cable after pulling it out. It was so corroded on the inside there were only about half of the strands left.
