BBC cams
464elcamino
144
alton illinois
What are you guys using in your BBC for a good strip street cam? Looking to freshin mine up over winter and lookin for a good lopey track/street cam. Heads are mild ported 781 with lunati roller rockers, 11.8:1 comp ratio, 1050 dom carb on a holley track dominator hi rise single plane int., 2 1/8" primary long tube headers, stg3 400th, 3500 stall, 4.11's .
bracketchev1221
1,111
Mountville Pa
First, I would put a smaller carb on it. The dominator is hurting more than helping. And no matter what cam you use, 3500 converter will not be enough. 12-1 compression can use like a 260/270 duration cam. I ran a Crane .628/.648 solid flat tappet in my 11.6-1 427 with 260/268 @.050. With an 850, it went 11.20's at 118 in a 3600 lbs car.
