What pan gasket are you using and why? I've pulled the engine out of my car for the second time for an oil leak and found that the one piece fel-pro gasket I'm using is coming apart....more so at the corners of the front and rear "saddles" (for lack of a better term, but it's the corners where the front/rear main seals meet the pan rails)
after the first time I thought it was a fluke and used a new one of the same gasket. This isn't the main source of the leak btw.....I'm re-ringing it with zero gaps in a effort to remove crank case pressure ](*,) could said pressure be chewing up the gasket?
scratching my head here :-k
