BBC motor mount question
81Regal
2,639
NW Iowa
I'm test fitting my BBC onto the new frame going under my monte and I'm running into a problem.
The frame was originally from under a Regal but I'm using stock SBC G body frame pads and insters from Energy suspension. I put the pads in the stock SBC location, got one side the bolt is in but the other side is sitting up 1 1/2- 2 inches. I don't believe I have the inserts upside down, could the engine side mounts be wrong to use with this setup?
TURNA
6,028
Socialist NY
Do you have a set of engine side mounts that look like the ones in this pic on the left side with the SBC on it?
If you do use those
81Regal
2,639
NW Iowa
I have a spare set of SBC mounts off a 400 I can try.
TURNA
6,028
Socialist NY
A friend of mine had the same problem with those Energy suspension motor mounts. he had to switch them around a couple of times to get them to work
81Regal
2,639
NW Iowa
Swapped on the SB mounts and they dopped the engne right where it needed to be.
