The closed chamber heads work just fine till about 6000 or 6500 RPM. The closed chamber shrouds the valves, sorta' hinders flow when you spin the snot out of them. The trade off, well, you don't need a set of dome pistons to make decent compression. They work just fine.
GM went back to a similar casting to 'pep-up' the 454 found in SS trucks. Full size oval ports and a 96cc chamber to make 8.5 or 9.1 compression. Pump friendly and plenty of thrust. In big block chevys, compression makes the power curve climb, find a desktop dyno, CompCams used to offer a free one, try it out.
I have also used the closed chamber Vortec big block heads on flat top 454's. I have also pepped up some 454's with 702 and its mate was like a 215. We used to call them '65 396 heads, or thats what most of them were.
I am also a big fan of the 781 and 049 oval port heads, I usually went with 2.19 1.88 valves (buy new take outs from boat guys real cheap). But, with flat tops, then you gotta' angle mill them for compression, or buy dome pistons.
