Has anyone gone to a T-5 from automatic trans and used the Camaro clutch hyd master cyl? If so did you use the stock power brake booster or did you have to use a different one? Thanks in advance.
Hey Turboapache,
When you do that swap the clutch MC ends up down on the floor so the stock booster/mc stays in place,check out
http://www.garage-scene.com/
It doesn't appear to be a hard job as a matter of fact I'm planning the same thing on a different car some time in the future,Later,KillerDave
