On my motor, i have the black rinkle Chevy engine dress up kit, but where that vac hose from the master cylinder should go, theres no hole, the gromets closer to #1 cylinder. Did any of you guys run across the same problem?
That vacuum line coming from the brake booster needs to be hooked to the large manifold vacuum port on the back of the carb. You can put a T in the line and run a hose to a PCV valve as well.
If you don't have the hole in your valve covers for the PCV and the filter you can take an appropriately sized hole saw and put them in there.
