anybody have them? i am still looking for an extreme set of 23* heads, do they need shaft mounts for the street like the AFR's? looking to make big power on a 23* head, any other recomendations?
I'd check into the pontiac raised runner Nascar heads. They flow huge numbers and you can sometimes find them used on ebay. A buddy put them on a 406 (somewhat mismatched to his milder cam) I think they need thicker intake gaskets and a rail or more silcone at the end seals of the intake. BTW there is nothing pontiac about them!
Brian
Be careful with the with the 867 heads.You will have to use a a set of shaft rockers and offset lifters on the them in most cases because of the 40/60 spacing. All the ones we've used needed .180 offset lifters as well as .250 offset rockers like the Brodix 10x. & 18 degree stuff. Count the cost and check into what the valve train is going to cost before you buy them.
