cam bearings
frost1085
144
Fort Wayne, IN
were should the bearings holes be facing when i put them in especially number one becouse it has to holes
1-5
oclock position and number one it has 2 holes
lilbowtie
1,736
Canton Mi.
Frost
To answere your first question I have used both with no problems - I find some people
leaning towards Dura Bond. With your second question I would go on line and do a little
reading on the subject. sbc has an oil gallery cut behind the bearing so it will get oil no matter
where you put the holes. From what I understand the 4:00 oclock posion is best which would
put your other hole for #1 @12:00 to 1:00
SSedan64
948
MACON, GA.
Placement varies from builder to builder. Look thru these 2 Threads, there're a few options but it should help you out.
http://www.hotrodders.com/forum/sbc-cam-bearing-alignment-135681.html
http://www.hotrodders.com/forum/cam-bearing-install-help-211871.html
