If you are set on a comp cam you can call their cam tech line and give them your combo and what you are wanting and they will give you a pretty good match.
But...
There are alot of cam companies out there and they all start with the same cores...lol
Try Bullet cams, Doug Herbert Performance, or Competition Products as well. There are alot of good cams out there that won't cost you the arm and leg it requires to get that compcams name.
P.S. Bullet has all the Ultradyne profiles from when that company went under. If you have ever heard of Ultradyne they were awesome bacause the owner just absolutely loved cam design. He close up Ultradyne and went to work for Lunati (that's where the voo-doo line came from, Harold). Great cams that sounded awesome and made excellent power. I still have a solid Ultradyne grind that will stay packed in a protective sleeve with a coating on it till I wanna use it again.
