chevy bolt pattern
built
979
ohio
trying to remember am I right that our malibu's use a 5x4.75 stud pattern on the wheels.
80malibucoup said:
you are correct,5x4.75 in and 5x120.7 mm,stud size 12x1.5
Unless it's an 80 or older. Then it has 7/16-20 studs...
... and the wheels are typically 0-offset, meaning the mounting point is in the center of the wheel, as opposed to being to one side or the other as with late model F-Body wheels. Once you get past a certain width you'll need to go with (I believe) 4.5" backspacing, or somewhere around that.
GM G-body 15" x 7" wheels aren't 0 offset. They're typically 3.75" backspaced, which is a -7 offset.
Hey, nobody's trying to point anybody out. :lol:
