Hey all, picked up an 87' Monte LS cluster with speedo, fuel gauge, three dummy lights and the MC logo in the tach's spot. I switched all the pins around for the connector on the back side, but I'm only getting the seatbelt light and the turn signals, but I'm not getting the choke, voltmeter, oil pressure, or coolant temp lights to come on. I followed the pin layouts listed in the tech section here and everything's right. It said to leave the brown wire out and that one is listed as "ALT LIGHT." So I'm assuming that with the cluster I have, you will need the two wires that the how-to said to take out? I'm supposed to be getting a speedo cluster with gauges soon but I'd at least like to figure this out in the meantime so I can drive the car.
Thanks
Thanks
