couple Strange S60 questions
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
Well, i purchased the S60 rear that was for sale in the classifieds, and i have a few question:
1) with the 11 ford drum brakes, can i run my e-brake? what will i need to make it work?
2) the axles have 5/8 studs, will i need to drill out the holes in my wheels to fit over these? theyre corvette rally's also, where can i find acorn lug nuts to fit the studs?
3) the rear has a detroit locker in it, which kind of additive should i use for the fluid?
thanks!
MISFITmalibu63
7,163
anyone???
Hiway
3,932
Enola Arkansas
lockers use regular fluid...no clutches.
speedway motors.com will have the lug nuts
ralleys holes are to small....not sure how much you can drill them
Why change from the 8.5? just askin
MISFITmalibu63
7,163
thanks! any info on the e-brake?
as for swapping out the 8.5, i planned to upgrade my axles, posi and studs on the 8.5, but when i did the #'s, it wasn't worth it. i plan to go to BBC, so i needed something stronger. i don't think i'll be able to kill the s60
Hiway
3,932
Enola Arkansas
I was thinking the same thing as Robert on drilling the wheels....but dirt trackers do that stuff often....but they are Dirt Trackers.
Robert1320
I think the wheels are different. But, I have done any r/r chassis work in............... well a long time.
