Crossmember question
Wile E
1,075
Central WISC
Will a th350 crossmember from a '79 work with the newer frame with the factory extension (84+) and a 2004r? Or will it (84+) still need a 2004r crossmember?
DOUG213XRJ
4,671
West, MI
I was told that a TH350 cross member will work for a 200 4R if the frame extension is used. I have a TH350 and a 200 4R cross member and they are not the same. So all I can say is try it.
Wile E
1,075
Central WISC
I thought the th350 crossmember would work with the 84+ frame extension and 200r4, apparently not unless I'm just looking at it wrong. I bought a G Force th350 crossmember years ago but plans have changed and I'm swapping over to a 2004r trans.
