Like lilbowtie said, Check your end play in the crank. Cranks have a "thrust bearing" at the rear section of the crank, when a crank is put in place you have to "snug" all the main caps and "push, pry, or wack" the crank towards the front of the block. Torque all the main cap bolts and check your Crank end play. By installing the Balancer with a "pound it on" method you will push the crank to the "back' of the block making the thrust bearing touch the rear of the block journal surface, causing excessive wear and possibly misaligning the main caps. It does sound a little scary but the old timers used to pound on balancers all the time. Here is some reading about thrust bearings and their role in a crank. I think it will be O.K.
http://www.4secondsflat.com/Thrust_bearing_failures.html
