Driver side sedan interior plastic pillar question
You need to remove the seatbelt bolts and the B-pillar trim, then slide the belt end out through the hole in the trim. Believe it or not, it does fit...
O. D. Showtime
2,851
Regina SK Canada
After removing the seat bolt at the floor and at upper pillar everything will fit through the hole in the B pillar. Best to put one piece through at a time. Upper anchor....buckle then the mounting point that came off the floor....might have to wiggle a little here and there....but I've pulled and sold about 4 nice sets....and the seat belt parts will go through.
