I need some help trying to figure out what is causing this drivetrain vibration. I have a 388 SBC/T56, custom made driveshaft, and a Quick Performance ford 9". the vibration is only evident above 65 MPH. Any other time you can't notice it. And the faster I go the worse it gets. I tried adjusting the pinion angle with some adjustable upper control arms and have it set up at -3 degrees. Running out of ideas. Maybe improperly balanced driveshaft? Or maybe a bad U-joint? Any suggestions cause I am all ears! thanks!
