Electric Fan Diode.
richamer1
524
New Carlisle, Oh
I need to install a diode inline. If the car is hot when I shut off the key the engine continues to run until the electric fan stops turning. It is a single Flex A Lite not sure exactly what current it is pulling. Had some LED's lying around first one was to big. LED would light but fan would not run. Others were to small without installing a resistor also. Any suggestions on this. ?
You obviously have a backfeed into the igniton circuit somewhere. A diode isn't the proper fix. Something's not wired right.
Ed Cannon
1,682
Johnson City Tn
Is your fan running off a relay? If not thats your problem.
