Im going from a stock rear in my 81 to a Moser 12 bolt with the Ford drum brakes. Will the original emergency brake cables fit or do I have to make a change ? They are already out since I was cleaning up the frame so if I need to change now is the time to do it. If the original stuff works I might buy a new set since they arent too much $ and then it will all be new front to rear. The only thing that I see I goofed on so far is that I got the whole line set from Inline and didnt take into consideration that the lines on the rear will be different from the stock to 12 bolt. I may be able to send them back for a switch. I hope ! Any other things that I might miss from anyone who has done this ?? Thanks
