Engine Oil???
kevind
868
Whitley City KY
Some people run a special break in oil. I just run what I'm going to run in the motor.
If it's a flat tappet cam, get something with a high ZDP content or use a break in oil additive specifically designed for flat tappet cams.
Supe
15,116
Charlotte, NC
Honestly, I wouldn't even think of breaking in a flat tappet came without adding an EOS anymore. Even the "good" oils have cut back so heavily on the zinc content, you don't know what's what anymore.
MalibuMan1979
506
flint, (lapeer), michigan
holtjohn said:
rotella T 15-40 and make sure to prime the motor first.
got this from shell rotella site. i heard this is good oil, but by a diesel engine standpoint. quote,'1210 ppm zinc'. here is the site.
http://www.shellusserver.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=3231&page=3
holtjohn
516
I just know Compcams says to use it, I have installed five cams in the last year and half without one failure.
'Bu-Camino
113
Spring, Texas
like the others have said above, the oils today don't have the additives they used to. Add a quart of GM Engine Oil Supplement (EOS).
A lot of high end engine builders use Brad Penn oil for break in, like the NASCAR guys.
http://www.bradpennracing.com/Products/BIO30.html
That being said, i've never had a problem breaking in a cam with the EOS, pre-lubing and making sure your engine fires the first time.
