Ford 8.8 in gbody
sostreet
Member
Jun 4, 2012
5
Dallas,Tx
How many of you have used the 8.8 in a Malibu and what exactly needs to be done. I see trz make a kit for the swap how bolt in dose that make it
Hy82e
New Member
Dec 6, 2012
Fort Worth, TX
Unless they have gone back TRZ stopped making the kits.
Check out baselinesuspensions.com get in touch with Kevin he can answer all your questions. I can tell you using his kit does make it completely bolt in as far as mounting goes. Some other issues will be width, bolt pattern, and brakes.
82dragonwagon
35
Mines got an 8.8 with 3.73 gears. I didn't install it but the previous owner did. I wish it was a 3.42 or so. Mine runs a lot of rpm's at 75 mph. Somewhere north of 2600. I'm going to put a taller tire on it which should help it out some.
sostreet
Member
5
Dallas,Tx
Do you guys know the backspacing if wanted to run 15x10 on the rear and thanks for the replys I'm just now seeing them
Blue Knight
383
I have an 8.8 in mine.
