heres a link to 8.8 sticky http://www.maliburacing.com/forum/viewtopic.php?f=4&t=72070
theres a pic of one.
Basic run down
250 housing made by JD race ands restoration center scetion from for LTD idk what years.. the ford GT top ears arent as similar to the gbody as the ltds are.
350 31 spline axles (250 for gbody 28spline)
450 31 spline carrier(junkyard 31 would be cheaper)
150 gears(included oem ford 28spline)
80 for complete r&p bearing overhaul
80 strange 1350 yoke
820.00 minus custom 31 spline axles and new carrier.
920.00 oem 31spline ford carrier and custom 31 axles
1360 to go 31spline with aftermarket carrier
i picked up a set of iceman DA upper to ease the clocking and centering of the axle
one of the guys asked about it... if your good at the junk yard you can get it all done and use oem drums and have a 12blot strength axle with 28spline for less then it cost to rebuild a 7.5 upgraded to 28spline..
