i found a set of 461 double humps was wondering if any one could tell me what size vavles they have one head has casting of 461 and the other is 462 isnt this a matching set and what cc are these heads
they should be a 64 cc chamber and some came with 202-160's and others came with 194-150's and im pretty sure they have the screw in studs. no they are not a matching pair but they are the same. Either one is a good set of heads and you can make some good power with those. How much are they asking? does anything have to be done to them?
You should keep the casting number the same if you want to keep the engines performance equal from left to right bank.
I would pass unless you have an extra 461 or 462 head laying around and REALLY you should get the same casting date or close as you can. OR intend on doing alot of work to make them equal.
Fueler heads cam in both 194 or 2.02 valve versions so you must measure the valve or seal opening to figure this fact.
The 461 and 462 heads are DIFFERENT and as stated should not be run on the same motor together...Will run off.
