Was having cage put in first, but been thinking about it and think it will be alot easier to do the notch and mini-tub before the cage is all the way in. Fixing to start cutting and want some opinions on just what will be enough bracing for the rear frame. I am putting 325/50-15 ET Street Radials under there and planning on cutting almost all the way to the inner skin and just boxing in the main rails. I took one of Elcorvino's pics and modified it a little to show the braces that I think I need to put in. They are the really bad looking yellow lines on the pic. The crossmember near the springs will of course go under the spring mount and between the shock and spring. The rear down bars of the cage will attach to this brace. The rear crossmember will attach to the frame where the rear body mounts attach to the frame and then will have triangulating braces forward. I need to know if this is enough bracing to race this car and do just a little bit of street driving!
